2,7 HDI stuck in park |
jenskuhn
![]() Member No: #2756
Hi. My car is stuck in park. I am only able to release it by poking a screwdriver into the right hand side of the gear lever. I have tried testing the function in Lexia (I can hear a small click but I am unsure if it is the right amount of click). Can the source of the problem be a relay? (And where is the relay located?) Or can it be something with the brake pedal? Any advice would be appreciated. |
Arnonf
![]() ![]() Member No: #4869
This is where the relay sits. When it triggers, it makes a noticeable click and pulls the white plastic lock downwards (this is what you are pressing to manually unlock). Are you able to move the gear shift out of P when using Lexia to unlock? If not, it sounds like either the relay or some electrical issue. ![]() ![]() ![]() |
jenskuhn
Arnonf wrote ... This is where the relay sits. When it triggers, it makes a noticeable click and pulls the white plastic lock downwards (this is what you are pressing to manually unlock). Are you able to move the gear shift out of P when using Lexia to unlock? If not, it sounds like either the relay or some electrical issue. Thanks for the answer Arnonf. You explanation was helpful. I can hear the clicking so I have ordered a used unit. How much disassembly is required here to remove the unit? Do I need to get under the car (and remove the exhaust system) or is it accessible after removing the console plastics covering around? |
TheGerman
![]() Member No: #3175
or is it accessible after removing the console plastics covering around? Es dürfte auch einfacher mit Austausch des Teils 240778 funktionieren. Siehe auch hier: - Click Here - |
