Citroen C6 ABS/ESP/HandBrake error P1536
Nadzi
Sun Jul 14 2024, 06:43pm
Member No: #5021
Good day, I have an ABS/ESP light on my C6.
Unfortunately, I do not have Lexia at my disposal, so I only have data from freely available diagnostics.
I have a P1536 error. I replaced the brake switch, but the warning light still didn't go away. Handbrake and ABS are functional when I try it. Do you know where else I could see the problem?
Mon Jul 15 2024, 07:55am
Nadzi wrote ...
Did you also change the new longer wiring harness as per - Click Here -
Have a look at this as well: - Click Here -
Nadzi
Thu Aug 01 2024, 01:22pm
Member No: #5021
Yes, I changed the cable harness together with the sensor. I only have one sensor under the steering wheel. On that website there is a sensor under the passenger compartment. unfortunately, I don't have a diagbox to find out more. any advice?
abs and handbrake work, but abs esp faults and handbrake faults are lit on the dashboard, but they work properly
