Drivers window goes up then goes back down!!
Rooster
Thu Aug 14 2014, 01:11pm
Hello again,
I have my C6 back up and running with a new alternator. One issue that has had the garage puzzled is that the drivers window will not stay shut. When it is raised to the closed position, it reaches the the top and then opens again of its own accord, as if there's an obstruction.
Has anyone experienced anything similar and can offer a resolution?
Cheers
Roost
Thu Aug 14 2014, 01:19pm
There is mentioned somewhere that after the car has been without electricity, there might be a need to "relearn" the window how to behave by stepwise rising it to the top position (or something like that)
Rooster
Thu Aug 14 2014, 01:36pm
Thanks Tjensen,
Can you please explain what you mean by 'stepwise rising it to the top position'?
Do you mean moving it up in short steps rather than letting it go up on the one touch close?
Pete
smorphet
Thu Aug 14 2014, 04:21pm
Member No: #88
This thread describes the procedure to re-initialise the windows: - Click Here -
Rooster
Thu Aug 14 2014, 08:26pm
Many thanks smorphet!
Rooster
Fri Aug 15 2014, 07:16am
Hi, Tried this method but to no avail. The window still reaches the top and then drops back down as if its sensing an obstruction.
Any ideas?
Thanks in advance. Rooster
Fri Aug 15 2014, 07:58am
Rooster, there may be a error in the BSI.
Check out my recent post on battery disconnection and more importantly battery reconnection, then follow window recommissioning to the letter.
If that fails, clear the error faults and error logs (you will need Lexia or latest software to be able to access the error logs. If there is a fault, it will probably be in the drivers door ECU and the same error repeated in the BSI
regards
Rooster
Fri Aug 15 2014, 10:35am
Hi gmerry,
Did you mean this previous post:
Hi all, the BSI is basically a computer so can become corrupted, especially if servicing has been shoddy/batteries have been removed whilst the computer is active.
Attached is a copy of a Peugeot procedure: I imagaine it would be the same or similar.
Put the driver's window down, lift the bonnet and ensure all equipment is switched off.
Ensure all doors are closed and remove key from the ignition.
Wait for 3 minutes, disconnect the vehicle battery and wait 15 seconds.
Reconnect the vehicle battery, wait a further 10 seconds (do not open doors.).
Switch on the side lights through the driver's window.
Switch on the ignition and check system's functionality.
Hold lock button on key down for 10 seconds.
Remove key open & close door test central locking system.
Start the engine and complete the system's check.
If so, thanks very much. I will try it
Fri Aug 15 2014, 12:37pm
Hi Rooster, thats it.
Remember for C6, battery is in the boot so dont worry about the bonnet but have the boot open before starting procedure.
You may still need Lexia to clear any faults or log overflow.
Best of luck
Rooster
Fri Aug 15 2014, 03:50pm
gmerry, I salute you!
Job done, all working perfectly.
Damn, these C6's are quirky......................
Sat Aug 16 2014, 08:05pm
Rooster wrote ...
OH YES!!!!
Rooster
Sun Aug 17 2014, 07:06am
Thank God I cane across this site. Its already saved me a small fortune and probably saved me from going round the bend!
Going here today - - Click Here - - and giving the C6 a blast down the M6.
Fingers Crossed!!
M2dis
Wed Jun 12 2024, 08:16pm
Member No: #3475
Bumping this old thread. Had the same issue, no matter how I tried to re-learn it, the window didn't want to stay up (even lifting the window with the manual (first click) mode and holding it in this mode, instantly scrolled to half way again).
And then I found this thread. BSI reset and relearning after it fixed the window.
