Reinitialising the Pinch on Front windows after battery change? |
yorkxx |
Member No: #1005
Hi Guy's, just changed the battery on my car and I noticed it say's in the handbook that you have to the re-initialise pinch/set up the front windows after battery change, the hand book doesn't tell you how to do this, I've searched this forum too and can't find it. Anyone know how to do this? Cheers Doug |
Hattershaun |
All you need to do is open the window fully, it will most likely only move down a couple of inches each time you press the button, so release the button & press again, repeat until the glass is fully lowered, then keep the switch pressed down for a couple of seconds with the glass in it's fully lowered position. Follow the same procedure to raise the window. Once completed, the one touch functionality will be restored, so give it a try. |
yorkxx |
Member No: #1005
Hi H, yes that worked thank's, I was at the Citroen garage today and they said the info required to re-initallise the windows was under the "Window's section" of the handbook, I was looking at the battery replacement part of the handbook where it say's refer to Citroen garage for procedure rather than just saying look at the "Window's section in this book. Nut's eh! Thanks Cheers |
