C6 Side window |
Microswitch in the door handle? When you pull the handle it sends a signal to drop the window and takes very little pressure Have a look at the other doors to see what I mean. |
travlician |
Member No: #350
Since the windows doesn't lower when the control in the door is pressed, it's seems more like the motor to control the window position isn't working.... | ||
Rich |
Member No: #542
If you need a cheap replacement, there is a C6 currently on eBay being broken for spares... |
magicands |
Its the microchip in the door handle as this would lower the glass regardless of the motor function or so I am lead to believe as the motor does not work without 12v power supply anyway and this is not present when the car door is opened? | ||
