Re-useable air filter for C6 |
Chris Burmajster |
Member No: #81
Now that the price of fuel is at an all time high and any version of the C6 is not wildly economical, does anybody know of a re-useable air filter for the C6? When I had my C5, I replaced the throwaway paper filter with a re-useable K&N filter which not only saved money in the long term, but gave an immediate 2mpg more. I've looked at the K&N website and they don't seem to make one for the C6. | ||
Mike H |
Member No: #53
Chris the airbox looks the same in a 2.7 HDI Peugeot 407 maybe search that too ? Not sure myself that they can filter as well as paper though ? Mike |
Chris Burmajster |
Member No: #81
Hi Mike, Thanks for tip. Just tried both on the K&N website - no joy on either! Chris |
Chris, not sure if I understand the basic premise here: For a turbo-charged diesel, why would a "reusable" air filter element improve mpg. If the standard air filter is blocked, surely the solution is just to replace the element. If the aim is to reduce the cost of air filter changes, what's the payback. Ie, how many changes or years before one breaks even on presumably the higher initial cost of a reusable element. Regards G |
Chris Burmajster |
Member No: #81
Hi G, My understanding is that filters like the K&N, which contain cotton sprayed with light oil, let more air through than paper filters, thus allowing the engine to breath more easily. I had one in my C5 (V6 petrol) and got an extra 2 miles to every gallon. K&N also claim that it increases throttle response. I admit that I haven't actually done the figures regarding the long term cost, but I like the idea of not throwing a paper filter away every 20,000 miles. I assume (!) that it'll be cheaper in the long run. Chris |
Diesel engines are a different beast altogether to a petrol one and you may find that a K&N actually reduces mpg | ||
Pretty sure the V6 Turbo diesel doesn't need "more air". Regards G |
Chris Burmajster |
Member No: #81
C6Dave wrote ... Diesel engines are a different beast altogether to a petrol one and you may find that a K&N actually reduces mpg Ah, interesting! Can you please explain why, as I'm curious to know. I would have thought that allowing any engine to breathe more easily would be beneficial. Chris |
K & N makes air filters for the petrol V6 version. I have very good experience with the low resistance reusable K & N filters for the XM and the CX Turbo, and would like to try a high quality filter for the C6 too. But so far: found nothing | ||
pgrant5 |
Member No: #3774
Hi, Just to let you know ITG air filters do list a performance air filter for the Citroen C6. |
Thanks ! I checked and it looks like it is just for the petrol version and for the 2.2 Hdi diesel. | ||
jamescarruthers |
Member No: #1548
I’ve always been told that these sort of things do a worse job of filtering the air and can cause erosion of valves in the very long term. They might let a bit more air in and make a bit more noise but is it really necessary? |
