MPH to KPH |
| Author | Post | ||
lee_marshuk
![]() ![]() Member No: #1584
Good evening, I have encountered a strange error with one of my C6s. When changing the setting in the RT5 from MPH to KPH (for driving abroad), nothing happens. Normally it will instantly change on the cluster. Any suggestions? Thanks Lee |
I had that happen once at Folkstone when going to France. I can't remember finding out what caused it or resolving it, and as I didn't go abroad that much, just lived with it.... | ||
lee_marshuk
Likewise I just lived with it, worked out the speeds in my head!! Thanks Dave |
lee_marshuk wrote ... Likewise I just lived with it, worked out the speeds in my head!! Thanks Dave The old Traction had a KPH speedo which 'waved about' a bit, so was fun in the UK so relied on the TomTom if any distance away from home, but could never break the motorway limit anyway For everyone else, here is a 'rough' comparison if outside the UK within +/- 1 mph Motorways: 130 kph = 80 mph 110 kph = 60 mph (in the rain) D Roads 60 kph = 37 mph 50 kph = 31 mph 30 kph = 18 mph |
lee_marshuk
Hello, I had to use diagbox today to investigate a fault with climate control. Unfortunately one side is reading - 30 degrees so I think I have the dreaded stuck flaps. But whilst in diagbox, I decided to check the bsi configuration and in the multifunction screen section, in the past someone had changed the setting for units from the default 'network information' to mph. Changing this back now allows the screen to change between mph and kph as desired. Thanks Lee |
lee_marshuk wrote ... But whilst in diagbox, I decided to check the bsi configuration and in the multifunction screen section, in the past someone had changed the setting for units from the default 'network information' to mph. Changing this back now allows the screen to change between mph and kph as desired. That's interesting and should help others who had similar issues being unable to switch between KPH & MPH |
