C6owners :: Forums :: C6 Market Place :: C6 Parts Market |
Headlamp ? |
My 3.0 Hdi LHD is not shifting to full light on the right side. Garage says new lamp is the solution. Price from Citroen is HIGH ! Anyone with a tip for a source? | ||
Have a look on eBay etc. for a used one. Plenty in the UK from around £150 but EU based would be better for you. There's a new one in Latvia - Click Here - |
Thanks !!!! (but this one is not for turning lamps) Will look at the others. Nice price | ||
eke
![]() ![]() Member No: #624
Hi Tjensen, Last summer I had same problem with my LHD and this was because the black/white wire was cut just before the connector. So I took the headlight out and fixed the wire and put it back, main beam worked again. - Click Here - Br Eke |
Will check !! Thanks | ||
