UPPER RADIATOR HOSE for 2006 C6 2.7L HDI : part number
citroenroen1
Tue Jul 02 2024, 09:50pm
Member No: #5495
I need the part number for the CORRECT upper radiator hose for my
2006 2.7L HDI .
I have looked AND looked but I have been unable to find a C6 upper radiator hose that looks like mine.
I cannot locate the part number on this site either.
Your assistance is greatly appreciated .
Wed Jul 03 2024, 10:40am
Is this what your after 1343 HK: - Click Here -
EDIT: 2.7 HDi Radiator Hose Part numbers now added to Technical Documents - Click Here -
Wed Jul 03 2024, 05:17pm
Upper (radiator inlet) hose 1343-HK
Item 21 in the link.
citroenroen1
Fri Jul 05 2024, 10:41pm
Member No: #5495
Thank you for posting 2.7 HDi Radiator Hose Part numbers to Technical Documents.
The hose I want is 1343HK.
This hose on my car has a small leak where it connects to the radiator : there is a "NUB" (square raised area) at the radiator end of the hose (hidden from view on the bottom side of the hose end) which I believe is for the original factory hose clamp to go around ?
A "single ear" (European type) hose clamp is used on my car and this appears to not properly seal the end of the hose onto the radiator as it does not have the "cutout" for the "NUB".
Has anyone experienced this problem?
What is the best remedy?
citroenroen1
Wed Jul 10 2024, 08:44pm
Member No: #5495
How do I tighten factory hose clamp on upper radiator hose at radiator end ?
Thu Jul 11 2024, 10:36pm
citroenroen1 wrote ...
Technically you can't. The factory clamp is a fit once clamp.
However, I have had some success using end cut pliers like these - Click Here - to tighten the clamp.
Alternatively, remove the factory clamp and fit a standard hose clamp of an appropriate size. To do so you'll need to cut the piece of rubber on the bottom of the pipe that the factory clamp passes through.
