Door cards and lighting
rwb
Sun Jun 23 2024, 11:58am
Member No: #1988
Only one of my door cards lights up -- and it's barely noticeable.
Therefore I think that I need to change the bulbs.
How do I get the door cards off?
I can get the torx head bolts out but then it's still stuck fast.
Don't want to just violence it off because that always ends with broken plastic clips/tabs.
What is the consensus on what replacement bulbs to use?
Do I need resistors for something? Why? What do you do with them?
Thu Jul 11 2024, 11:06pm
Have you removed the T20 screw at the rear end of the door card just below the lock?
You also need to remove the tweeter and it's housing at the front as the card lifts up to remove once you have released the clips by pulling it from the bottom. The clips are a good design and unlikely to break when using appropriate force to pull the card from the door. I recommend using a trim removal tool to help the process but be careful not the scratch the paint.
Oh and you need to remove the ashtray (where fitted) as there's a hidden T20 in the bottom. You also need to remove the switch panel to disconnect the cable(s) and the puddle light at the bottom just levers out. I think you might need to remove a cover on the lock leaver but don't quote me on that one!
Can't help on how to make the lights better as my cards are black and therefore the lights are redundant!
rwb
Mon Aug 05 2024, 08:09am
Member No: #1988
Bolts, ashtray, speaker, puddle light all come out no problem.
Do you then just pull really hard?
Mon Aug 05 2024, 10:48am
rwb wrote ...
If you're sure that they are all out, start at the bottom edge and expect to break a few plastic clips....
rwb
Fri Sep 06 2024, 01:42pm
Member No: #1988
Pulled as hard as I dare but it's not for shifting.
More violence?
What clips are they? I have some 6991.Y8.
Fri Sep 06 2024, 02:32pm
rwb wrote ...
More violence?
Are you 100% sure that ALL the screws are out around the edges, down in the centre pull at '3' you only need the screw 'd' removed, the switch unit should come out on the card.
Ignore 4, 5 & 6 as they don't affect the door card removal
rwb
Thu Sep 19 2024, 07:55pm
Member No: #1988
Finally got round to having another go.
1 screw underneath the ash tray
3 screws in the top of the door pocket
Puddle light out.
Then what?
Thu Sep 19 2024, 08:12pm
tweeter and housing off at the top front.
T20 screw on the lock end about 150-200mm down from the top
door lock trim
switch panel
Then leaver a clip loose at the bottom rear corner and follow around to other clips. Once all the clips are loose, lift up and withdraw from the door. when withdrawing disconnect the ambient light.
rwb
Sat Sep 21 2024, 01:46pm
Member No: #1988
MGmike wrote ...
door lock trim
switch panel
OK
MGmike wrote ...
No such thing.
MGmike wrote ...
Yanked it really hard and there was an almighty crack and it won't go back on.
Sat Sep 21 2024, 05:56pm
rwb wrote ...
MGmike wrote ...
No such thing.
There should be! Is there a hole where a screw should be?
rwb wrote ...
In your picture you can see the two halves of the clip (pink and orange bits). If they are lined up correctly all you'll need is to give the door card a bash with the side of your fist to get it back in. Once it's been off a couple of time it gets easier
Sat Sep 21 2024, 06:05pm
Ah, just realised from the pic you're doing the rear door! No T20 on those and no tweeter in the top corner.
BTW the lights don't show well on a black interior. Before you rip the door card off stick your hand under the light to make sure it's not working. Also, it's a LED projected along a clear plastic rod. These are very unlikely to fail but I guess not impossible.
Sat Sep 21 2024, 07:47pm
MGmike wrote ...
....BTW the lights don't show well on a black interior. Before you rip the door card off stick your hand under the light to make sure it's not working. Also, it's a LED projected along a clear plastic rod. These are very unlikely to fail but I guess not impossible.
Really don't show much light unless it's really dark outside. Under street lights they don't show a lot.
There was a thread on this many years back IIRC
rwb
Thu Oct 24 2024, 03:50am
Member No: #1988
Definitely only the driver's door is working.
MOT day today -- setting off to Welwyn Garden City at 5.
Dreading it.
Since booking the washer pump has failed and the passenger door glass isn't dropping.
If I get home today then I might feel optimistic about having another look at the weekend...
So: just put harder?! (That feels very wrong.)
