Suspension fault |
Rosb
![]() Member No: #4784
I don’t have a lexia but do use An Autel bidirectional tool. For some time I have been getting suspension fault coming up and the suspension becoming irrational. The Autel says I have 2 permanent faults C1172. Right front AMVAR actuator- circuit open or short to ground. C1195. Average travel of front axel - value incoherent. I have just replaced the spheres and car has 2 new front struts, new regulator unit and a lot of the front suspension bushes and ball joints have been replaced. Also recently replaced the steering wheel sensor unit and I am getting an incoherent value code .U1205. I am not sure how to proceed from Here. Any advice much appreciated. Regards John |
Hello John, Did you check out the plug and socket? - Click Here - Best regards, Phil C. |
