Power steering parts |
Rosb |
Member No: #4784
Hi, I have a 2006 2.7 and need to address a suspension leak on the power steering pipe assembly. According to my Vin the parts a mechanic said I needed are 4014JA, 4012F2 and 401376. When I log in these numbers they seem to come up discontinued or maybe superseded. I know from a previous entry one of the numbers is listed as 4014HZ. Just wondering if someone can steer me in the right direction as I know the main pipe has a history of leaking so should still be in production. Regards John |
cit-rotti |
Member No: #3753
The spare part number 4012F2 is still current and still available from Citroen. The other spare parts probably have changed numbers. To determine the correct current numbers, the complete VIN is required and whether it is right-hand drive or left-hand drive. - Sometimes also the ORGA number. The correct spare part number can only be determined by calling the Service Hotline (https://public.servicebox-parts.com/pages/index.jsp). All other spare parts portals are often helpful but outdated - the spare part number is often still correct - but not if the last change was made only 3-4 years ago. Possible solutions: Either go to a Citroen workshop and have them find out the new numbers, or go to the forum - Click Here - log in + register + donate then you get the current numbers from the service hotline. or a forum member has access to the service hotline and helps. Greetings Wolfgang |
