citroen C6 2006 driver door window inoperative
mõmmi77
Fri Oct 28 2022, 12:42pm
Member No: #5122
Hello!
do you have experience? when opening the door, the window does not move down and the window opening switch does not work either. changed motor and switch, same error! other windows work!
jamescarruthers
Sun Oct 30 2022, 11:59am
Member No: #1548
Isn’t there a micro switch in the handle that energises to let the car know to move the window down before the handle mechanically opens the door? You could temporarily swap a handle over to see if that fixes the problem and proves that one of your handles has a broken switch?
Sun Oct 30 2022, 04:10pm
jamescarruthers wrote ...
The internal door lock mechanism controls the window lowering/raising as part of door opening/closing, activated by a micro switch.
These are known to fail. As far as I'm aware the whole door lock mechanism needs to be replaced.
mõmmi77
Mon Oct 31 2022, 02:08pm
Member No: #5122
Hello today i found that driver door lock is not locking, not from key buttons and not from key lock. seems to be that car lock system do not understand what position is driver door?!?
mõmmi77
Fri Nov 18 2022, 08:01am
Member No: #5122
It was door lock problem, now is ok.
