Greetings from Preston (part 3) |
Steve, I think it's just bad luck/timing m8! There are no ABS connections anywhere near the bumper. There's only the two plugs on the off-side for the lights, parking sensors etc. Is your battery fully charged after standing a while? Otherwise it's a plug in and check the codes day. Good luck |
Mike, Thanks kind of what I figured, I’m off on Tuesday, will get diagbox plugged in....... can’t wait ???? |
OK, so the saga with the ABS was down to my own stupidity when you change the comms 2000 you have to align 2 holes, I didn't thus throwing the steering wheel angle sensor false messages, which in turn caused the ABS issue. Quickly resolved by Robert at BL Autos. Next we have the towbar, which was put on the car whilst I was at BL Autos and worked perfectly, until I got home and decided two weeks later to take the car out for a run. I got the "rapid" flash of the indicators, like when you have a bulb out, and the reversing sensors stopped working. After playing around with the 13 pin socket I noticed a bent connection and straightened it out and the rapid flashing stopped. GREAT!!! Nope, I've had the same problem again today, so I got Lexia connected and removed the Trailer relay in the BSI and the disabled the configuration. now I have the indicators flashing correctly but the rear parking sensors are disabled and I can't find anywhere to enable them. |
