colling Fan fault 0493 |
| Author | Post | ||
joaoproenca
![]() Member No: #1510
Dear All I have following symptoms -error code 0493; right engine cooling fan is not working left engine colling fan works always at high speed Did not start to dig into issue - i will start to look into fuse; - connect right fan directly to see if it run with direct energy supply; I m also looking into electric diagram of colling system in case i need to dig more Warm regards Joao |
![]() ![]() Member No: #954
If the solution is like the one in XM V6, one of the relays (2 of them) may be the problem. | ||
joopajaa
![]() Member No: #3261
I have P0495. Right fan has been broken for long time. Now left also stopped. Can I test these fans by just by putting 12V to pins? Relay is right hand from cooler? I have 2.7 if it matters. |
Yes, test with 12v at the fan pins but I find it easier to jump the relay. Relays do fail and I have replaced both of them on a 2.7 in the past. |
joopajaa
MGmike wrote ... Yes, test with 12v at the fan pins but I find it easier to jump the relay. Relays do fail and I have replaced both of them on a 2.7 in the past. 2 relays? location? |
joopajaa wrote ... 2 relays? location? Yep, left side (from driver seat) of the cooling pack on top of chassis rail. |
