Does the radio have a separate battery for memory ? |
| Author | Post | ||
jannelehtimaki
![]() ![]() Member No: #1374
Hi, My radio (on 2009 3.0 Hdi) seems to loose the pairing with cars VIN-number on cold mornings (=> the beep from loudspeakers). After driving some time and restart of the car its all ok again. Would like to know if there is a failing lithium battery or something similar that can be replaced or do I face a failing soldering etc. issues that need electronic professionals input. |
CitroSuède
![]() Joined: Feb 12 2014 Member No: #1582
Hi! Did you find any answer to this? I have a similar problem with my car, same loud beeping but it's intermittent. Always comes together with no temperature monitoring for the heating and sometimes no parking sensors working. Greetings, Chris |
![]() ![]() Member No: #954
Can it be a harddisk/restart problem ? For a long period I had black screen, then restart. An after restart some services was out and needed to be installed again. After new harddisk the problem disappeared. | ||
AndreSMCXXMC6
![]() Joined: Sep 09 2011 Member No: #615
There is actually a separate battery in the RT4 / 5 radio | ||
jannelehtimaki
CitroSuède wrote ... Hi! Did you find any answer to this? I have a similar problem with my car, same loud beeping but it's intermittent. Always comes together with no temperature monitoring for the heating and sometimes no parking sensors working. Greetings, Chris Mee too, -have anyone found a solution ? |
jannelehtimaki
AndreSMCXXMC6 wrote ... There is actually a separate battery in the RT4 / 5 radio Thanks, have you any idea how to access the battery ? |
