How to remove the radio
Ciaran
Sat Sep 23 2017, 06:18pm
Lads,
Maybe a stupid question, but how do you remove the radio / head unit?
I have all the usual removal pins etc, but there is only one hole at each side of the unit. There is a plastic strip along the top of the radio, under the vents, which looks like it may pry out with trim tools, but it seems fastened quite firmly and I don't want to break something.
Am I missing something really obvious? (probably)
I've spent quite a while searching on here and Google, but can't find any direct reference to it.
Answers on a postcard, much appreciated!
Ciarán
Cisco
Sat Sep 23 2017, 11:21pm
Member No: #1429
Hi Ciaran,
You need a long Torx T10 driver in each of the two holes to loosen the captive fixing screws then the head unit pulls out. Deploy the cup holders to get a grip on the unit.
Double check the Torx size as it's a while since I removed the unit.
ATB Frank
Sun Sep 24 2017, 12:42am
Yep. T10...
Ciaran
Sun Sep 24 2017, 03:50pm
Thanks guys, appreciate it.
I was poking the solitary hole with the removal pins and wondering was there a second hole hidden behind the trim strip or something - D'oh!
Cheers again.
Ciarán
