The piloted alternator in the 3.0 and its problems
Mon Jun 24 2019, 04:23pm
The sensor just came up as Lexia error report and was changed, not expensive
The steering flexible pipe is a quite common error, develops leak due to wear and vibration. Expensive part and difficult to repair, it is on the pressure side of the system. Your solution using a hydraulic service should be a solution. I never had vibrations, but maybe they did not follow all Citroen procedures when changing the pipe ? (air in the system, too low level of LDS or......)
Mon Apr 06 2020, 05:04pm
Sorry for very delayed answer !! Car is now OK, the old alternator got the "2,7" clutch with a spacer and is now a spare. The hydraulic pressure sensor was changed due to Lexia message. No link to the other fault. I also changed the (expensive) steering pressure pipe. Quite common problem. No experience with a quick fix, but should be possible.
Mon Nov 14 2022, 06:51pm
Update: The new generator was delivered from Germany at a low price, but with a wrong freewheel, it did not even turn ! Went back and got replaced and now without problems for 8 years/90 000 km. The old generator fixed and tested with a new freewheel and spacer.
The sensor for hydractive pressure was just changed by the garage. No issues.
The steering high-pressure pipe had developed a leak (quite an ordinary problem and an expensive part)
mihaigabriel
Fri Jun 28 2024, 03:59pm
Member No: #5144
Hi,
Could this be a good replacement for the original alternator pulley 3.0HDI?
SNRA - 806100 (found it on the French site oscaro.com) Part costs 24 euros on - Click Here -
Regards,
Go to page   <<
