LDS leaky HP pipe assembly replacement... |
| Author | Post | ||
![]() ![]() Member No: #1163
The one with the crimped flexi section around the midpoint -- usually sleeved with a concertina-type Nylon jacket -- and runs from the rear of the LDS pump block to the comfort sphere block, which is ahead of the r/h front wheel. Part nr is 5270VN; it's about £120; I replaced mine a fortnight ago, and it takes a couple of hours: Suspension on highest setting - Bumper off (after removing both front wing forward liners, incorporating the LDWS sensors, and the forward centre undertray section) R/h headlamp out Turn the steering hardover to the right REMOVE THE VERTICAL BRACE (two bolts, 16mm & 18mm heads) fwd/inboard of the comfort sphere Disconnect the three little connectors from the w/screen wash reservoir (they're colour coded) under the sphere Remove the 10mm hex-head machine screw (bolts have shanks; machine screws -- or simply just "screws" -- are fully threaded!) from the bottom of the w/screen wash reservoir Lift-and-pivot the reservoir on the upper Pop-rivet and support it with ty-wraps Suspension on lowest setting - Disconnect the main power and the single-wire connector from the LDS pump motor Manipulate coolant/hydraulic hoses away from the work area and do the same ty-wrap thing Depressurise the LDS system (not certain if this is essential, but I did it anyway) Notes: There are two P-clip-type retainers under 10mm nuts along the pipe (a ratchet spaniard is helpful); these support the rigid sections before and after the flexi crimps. These are best removed before dropping the suspension. One is alongside the LDS pump body, the other is close to the comfort sphere and within the wheel arch; there's also a plastic snap-over clip behind from where the brace is removed, ahead of the comfort sphere. Removal of the comfort sphere isn't necessary. The unions are 11mm A/F 'nuts'. Ensure that the tiny Green O-rings and the white spacers come out with the pipe! You'll need a small, strong light to show you the way. |
E3 Steve, Phew! Not wanting to be a spoil sport, but I fitted said pipe several weeks ago to the 2.7. What I did was remove the forward right hand wheel arch liner (and undertray of course) and the intercooler pipe to the butterfly box. I also depressurised. To fit the new pipe, I found I could feed it through the gap forward of the drop link you refer to from the comfort sphere side. Working then under the car, I had room to maneouvre the pipe and rotate it into position. Unfortunately it took me two hours to figure out how to do it, after repeatedly trying to install it from the engine side and failing. Weary, I took a break and while rambling to the local shop for a breakfast roll to console myself, I thought of the gap in front of the drop link and would the pipe feed in from the opposite side? So after said breakfast roll and a cup of tea, I had the pipe installed quickly. Hope this helps, Best regards, Phil C. |
robingc33
![]() ![]() Member No: #2303
Great info thanks guys. Robin |
![]() ![]() Member No: #614
robingc33 wrote ... Great info thanks guys. Robin I second that sentiment. Learned something new from those postings guys. |
cruiserphil wrote ... E3 Steve, Phew! Not wanting to be a spoil sport, but I fitted said pipe several weeks ago to the 2.7. What I did was remove the forward right hand wheel arch liner (and undertray of course) and the intercooler pipe to the butterfly box. I also depressurised. To fit the new pipe, I found I could feed it through the gap forward of the drop link you refer to from the comfort sphere side. Working then under the car, I had room to maneouvre the pipe and rotate it into position. Unfortunately it took me two hours to figure out how to do it, after repeatedly trying to install it from the engine side and failing. Weary, I took a break and while rambling to the local shop for a breakfast roll to console myself, I thought of the gap in front of the drop link and would the pipe feed in from the opposite side? So after said breakfast roll and a cup of tea, I had the pipe installed quickly. Hope this helps, Best regards, Phil C. A cup of tea always helps, Phil! It's really not so bad with the bumper off and the headlight removed. Access is tres dificile without doing that bit. I worked the new pipe downwards, from the engine bay. I remember your comment, when we last met up, about having to bend it to get it in; I suspect it did get slightly reshaped at some stage of my version of the operation, but not to any great degree (or "degrees" )...
"Weary, I took a break and while rambling to the local shop for a breakfast roll". I thought they were banned Phil by the health brigade after the recession started! I can't get anything fixed without at least a cup of tea! Or two! Keep up the great posting guys, makes for great reading. |
E3 Steve, When we met, I had completed the job on the 06 car. However when it came to the 07 car I had forgotten how I had done it. Then, as described, I worked out a revised way which made installation possible without distorting the pipe and was much simpler!!! Best regards, Phil C. |
321Dave, Moderation is the key. There's no harm in the odd breakfast roll!!! - Click Here - Best regards, Phil C. |
Lol.. very good Phil | ||
M2dis
![]() Member No: #3475
Just leaving this info here since 5720VN is not available from Citroen anymore, autofrance.dk is remanufacturing the pipe - Click Here - It is also possible to buy second hand pipe like I did 2 years ago, now the second hand pipe started leaking. The pipe from autofrance.dk has not been delivered and installed yet, I will update the post once it is. Edit// I received the pipe, their web shop is a bit out-dated but they did send a link in email where you could pay with "one click", and posted it next day. Delivery to Estonia took 4 days. My mechanic fitted it today and my C6 is leak free again! Everything is good at the moment. If the pipe wont hold the pressure for a long time, I'll come back and edit this post |
M2dis wrote ... Just leaving this info here since 5720VN is not available from Citroen anymore, autofrance.dk is remanufacturing the pipe - Click Here - Thank you for the info. @ Current exchange rates, they are around £174 GBP |
