A old love...the C6. Need some advises |
AlexKrausz |
Member No: #2210
Dear Members. Good evening. My name is Alex Krauss. Finally I have the opportunity to buy a 2 hand C6 here in Brussels. It is a Citroen C6 2.7 HDi V6 Autom. 205cv Exclusive full options. My big concern its the millage...250.000. The car seems to be in excellent state. Nevertheless, the millage is something that worries me. What is my dear Members opinion on this issue, and shall I be concern or look in this car. Thank you all for the care and time. Wish you all an excellent week. Yours, AK |
Mileage is not a problem if maintenance is good and documented. Timing belt (and water pump) should have been changed, glowplugs,,, Particle filter system overhauled. Hydraulics should be inspected, together with wheel bearings, lower front joints, suspension struts etc. | ||
AlexKrausz |
Member No: #2210
Thank you so much for your advises Tjensen! | ||
In the UK a car with that mileage might only cost 4,500 euro so how much are they asking for it? | ||
David K |
Member No: #42
I guess it is this car: - Click Here - Be aware that it is most likely not built in 2009, since it doesn't have the RT5 Navigation system. Just make sure the maintenance is done correctly. And as Tjensen said, the timing belt and water pump should have been exchanged at latest 240.000 km. |
AlexKrausz |
Member No: #2210
David K. Thanks for your msg. In did, that is the car. Will take in account your advice. | ||
patcrean406 |
Member No: #1894
Great value car. You got it so cheap you can afford to fix it. | ||
