2.7HDi V6 Auto Gearbox Jerky Shifts |
grandadmark |
Member No: #508
I have just experienced the same problem with my C6. a big clunk and then the warning message Gearbox faulty/malfunction. I intend to get Frontlines to check it out and change the oil BUT Can I still drive it until they can book me in !! Any thoughts on this? |
jamesh |
Member No: #196
I've been driving my car with the gearbox issue for the past 50,000 miles. I was so annoyed with Citroen's attitude to fixing it under warranty I was going to get rid of the car as soon as I found something I liked more. That hasn't happened yet, so I have had some quotes to have the work done. One garage has looked at the car and quoted £3.1k for a total rebuild, and another garage has said £900 all in for the valve block, or £1800 for the rebuild. I am not sure changing the oil will help if you've already got a "Gearbox Faulty" message. |
Oil changes are 'cheap' in comparison to gearbox rebuilds so what have you got to lose? | ||
grandadmark |
Member No: #508
Thanks for the replies however I need a revisit to this problem. I had the fluid changed and all was perfect until this Christmas. I am now getting high revs on changing gear when up to temperature and sometimes a clunky engagement on pulling away from stop. but only in town. Motorway driving is still great. I was considering a second fluid change in the new year anyway as car has done 70,000 now. Any advice on whether this is sensible using my local man again, or should I go for a gearbox specialist for diagnosis in case the control box is damaged. If I do need a specialist can any one recommend one in Sheffield area. Many Thanks in anticipation Grandadmark |
If you only had a partial oil change, I would take another or arrange for a full clean/flush change before doing something expensive.... | ||
grandadmark |
Member No: #508
many thanks for the reply Not sure about the oil change will ask my garage and if necessary get a full flush etc before doing anything expensive. Cheers Grandadmark |
paulx19car |
Member No: #2431
I have a similar problem too. Mines is in a local Alfa specialist over new year to have gearbox flush and new oil and if there is one a filter? It shares a gearbox with the Alfa 166 by all accounts so this trusted Alfa specialist should know what he's doing. I'll report back if it's a fix. |
Hi Paul, re the Aisin box in your car:- 1/ There is no service filter 2/ Different box* to Alfa 166 (Alfa 166 introduced several years before the box) 3/ Make sure your Alfa specialist knows how to set the fluid level - box must be hot and the fluid has to drip over the internal standpipe) Regards * Early 166s Autos are ZF, Facelift? are Aisin 5 speed. G |
Yup. | ||
paulx19car |
Member No: #2431
Ok 3 oil changes later..... its still a bit [%*^#@!]..... I'm gutted, I guess I'm going to have to bite the bullet and have a new valve body put in. |
paulx19car wrote ... Mine gets the jerks on the odd occasion, but not enough to get me to take it to BL Autos yet.Ok 3 oil changes later..... its still a bit [%*^#@!]..... I'm gutted, I guess I'm going to have to bite the bullet and have a new valve body put in. It also 'flares' on upshifts from 2 to 3 and, sometimes, 3 to 4, although this is infrequent; perhaps once every two or three months. |
Hi just a reminder, changing the box fluid is mainly a preventative measure NOT a remedial solution. Regarding harsh shifts and flares, these can be addressed in some cases by restoring the solenoid clearances, see previous posts. Regards G |
C6 DEN |
Member No: #2200
I had a strange auto happening in my C6 2.7hdi auto! It has been driving as smooth as silk (I don't boot it anyway!) when in a car park I drove it around quite fast & aggressively for a short while...Then...It wanted to snatch at 2nd gear and seemed in the lower gears to be "Lumpy"! After driving it home & being parked up for a few minuets it was back to being as smooth as silk again! No booting it this time !! Is this a precursor to further trouble?? I Haven't had the car for very long it is not a daily driver. |
C6 DEN |
Member No: #2200
Of my experience with the C6 I mentioned above ....is this normal...or am I headed for trouble? thanks C6 DEN |
Do you have any reliable evidence that the transmission fluid has been changed? Have you done this yourself? regards G |
