No replacement air mix flaps available or heater box servicing kit? |
Cisco |
Member No: #1429
Hi Jim, Sorry your selling the Six but good luck with the sale. Let me know re. the flap when you can. Now that you have some serious experience of this job it would be great if you could draw up a template for the best cutout size if you have the time. ATB Frank |
JimC |
Member No: #229
Hi Cisco, Sorry for the delay in getting back to you ... I've been busy getting laid-off! I did end up using my spare passenger side flap but can do a repair to the broken one I took out if you're wish to go that route. Alternatively, you could go to the same place I did (Pug 407) as that was a fairly painless exercise to get new flaps sent north north. The passenger side looked like it was going to be a nightmare due to extra (cooling?) pipes running alongside the heater box. However on closer inspection it was easy to get to the part I needed (higher-up above the pipes) and the whole 'cut - replace old for new - glue back' job took about an hour in total! Let me know if you need pictures & script from that exercise. Cheers, Jim |
Cisco |
Member No: #1429
Hi Jim, Any pictures you have will be great ATB Frank |
JimC |
Member No: #229
This should help... | ||
JimC |
Member No: #229
Hmmm... how do I attach a 760KB pdf??? | ||
JimC |
Member No: #229
If anyone else wants my home-made instruction manual... send me instructions on how to upload to the "Member Supplied Tutorials and other Downloads" section ) |
Jim, email it to me - e mail - and I'll get it uploaded |
David Hallworth |
File now available in the Downloads section. If there's any problems with it, let me know. David. |
Thanks to JimC and David for the upload. Best regards, Phil C. |
thanks to Jim and David. Great writeup | ||
Cisco |
Member No: #1429
Hi Guys, Replaced the passenger side paddle today following Jim's excellent tutorial and have included a photo of the completed repair. The dots are tippex showing the cut line. I also had an issue with controlling the ac temperature separately by the passenger control and was going to replace the humidity sensor as Diagbox was telling me it was faulty, gave it a brief shake and it's cooking on gas again |
Cisco |
Member No: #1429
Try again.. |
Cisco, what type of glue did you use to secure the cutout section of plastic? thanks |
Cisco |
Member No: #1429
Hi Gordon, Unibond plastic epoxy from B&Q @ £6.00 a pop. ATB Frank |
A job to look forward to Steve (Trainman). Looks like it's a good test of your physical flexibility!! Best of luck, Phil C. |
