Order for Front Spheres |
Hi all, I'm about to place an order with a UK supplier for I.F.H.S front spheres: their part number C650FH. Cost is £41.95 plus VAT plus a small amount for delivery. FOR 6 CYLINDER CARS ONLY The leadtime is 6-8 weeks so no point buying these when you need them in a hurry. With this leadtime I expect them to be factory fresh (not 4 years old as some of us have noticed with other suppliers). Currently the UK stockist does not stock anything for the C6 because there is no demand - but that is a chicken and egg situation. Note that Citroen spheres are about 3 times this cost and I have had poor experience with other manufacturer's products. Anyone want to add to the order? Regards G |
Hi all, I'll leave this until next Thursday 4th April, on which day I'll place my own order. Regards G |
eke |
Member No: #624
Hi, I might be interested, but I'm living in Finland. Do you know if they ship to Finland ? Regards Eke |
Eke, UK supplier is quoting £18.50 to ship two off spheres to Finland. Regards G |
rogerandoutman |
Member No: #466
I bought two front suspension strut spheres from Suplex(01909 770 660) last year. They are a German maufacturer and had them delivered next day, as then they held stock. Price was £36.06 each and are still holding up OK |
rogerandoutman |
Member No: #466
sorry, should have added the part no, which is 75145 | ||
eke |
Member No: #624
gmerry wrote ... Eke, UK supplier is quoting £18.50 to ship two off spheres to Finland. Regards G Ok, thank you. I had the front spheres checked today and they were still ok. So no need for me this time. Thanks anyway. |
Hi all, Suplex front stiffness sphere lasted less than a year. So I won't be fitting any more Suplex! Regards G |
rogerandoutman |
Member No: #466
Did they just lose pressure over time or did the membrane have a catastrophic failure? My original sphere failure was total, even though there was no springing effect from the nitrogen which has completly gone, Neither of the two Citroen main dealers diagnosed the problem, told me this is how the C6 rides, had to go to B&H to get it sorted | ||
Hi Roger, Suplex stiffness sphere lost pressure so ride became crashy on bumps. The OEM spheres have spikes that puncture the diaphragm: not sure if any of the aftermarket spheres are the same. Regards G |
Hattershaun |
rogerandoutman wrote ... Did they just lose pressure over time or did the membrane have a catastrophic failure? My original sphere failure was total, even though there was no springing effect from the nitrogen which has completly gone, Neither of the two Citroen main dealers diagnosed the problem, told me this is how the C6 rides, had to go to B&H to get it sorted Hi Roger, I think you are referring to B.L.Autos (Barry Lowdell) in Welwyn Garden City when you say B&H. I've been a customer of theirs for many years and they mentioned a C6 with the same symptoms as yours. I gave them my sphere pressure checking equipment ( a genuine Citroen workshop tool from the good old days of LHM and green spheres) to use, so if you wish they could check the pressures on your other spheres. Bizarrely, Citroen Hatfield recently borrowed this tool from B.L.Autos, so they could check & subsequently replace the spheres on a C5 under warranty. It makes me chuckle that the main dealer is borrowing equipment form an independent Citroen specialist! |
Hi all, my order has been placed with AEP Direct tel 01416470800. At present, they do not list the C6 IFHS spheres on their website so you will need to telephone the order through. I required that the spheres I am ordering are less than 6 months old: ordered in April, they were made in Feb 2013 so should be good. For reference, the IFHS part numbers for 6 Cylinder C6s (2.7 Diesel, 3.0 petrol and 3litre diesel) are:- Rear spheres C640RP (suspension and stiffness regulator) Front suspension C650FH Front Stiffness Regulator C670FR Regards G Note how the IFHS part numbers reference the car and the pressure |
