The Eolys Powerflex additive must never be mixed with Eolys DPX42, Eolys 176 or Infineum F7995 |
citroenroen1
![]() ![]() ![]() Member No: #5495
I JUST READ THIS: "The Eolys Powerflex additive must never be mixed with Eolys DPX42, Eolys 176 or Infineum F7995" This is from one supplier. I DON'T know what is in my DPF tank . (or how much) Should I try to drain the DPF tank before I add any new fluid? Then I read " Universal cerine allows you to have only one reference to store. It is compatible with the EOLYS DPX42, EOLYS 176, the infineum F7995 and the EOLYS PowerFlex." This is from another supplier suggesting that "universal cerine" is compatible . What would be the guidance ? I don't know what to believe. Can I be told where exactly my DPF reservoir is located on my C6 and how to gain access to it in order to fill it ? Thank you! |
It's all well discussed in the forums with several threads on it: - Click Here - In the Tech Docs: How to refill the (Eolys) Fuel Adfditive Tank: - Click Here - |
On the question of alternative 'additives' you first need to look under the car and see if yours has a 're-fillable' tank as the system did change to removable click and fit 'pouches' which tend to leak, and should be replaced. | ||
