Serpentine belt TENSIONER part # ? |
citroenroen1
![]() ![]() ![]() Member No: #5495
I would like the part number for the C6 serpentine belt tensioner . There must be 2 different serpentine belt tensioners, because the one I have has a big spring . |
![]() ![]() ![]() ![]() ![]() Member No: #3151
5751 C5 for the 2.7 and 3.0HDI Only the 3.0 petrol and 2.2HDI have different tensioners. please post a picture of you tensioner to confirm the number is the correct one. |
citroenroen1
Thanks for your reply Mike. I am unable to get a good picture of my tensioner I googled the part# 5751 C5: tensioner for Citroen C6 and nothing came up. I found this listing: "1611424480 BELT TENSIONER PEBBLE FOR CITROEN C5 III C6 407 607 2.7-3.0 HDI." on EBAY. Is same serpentine belt tensioner used on all C6's? |
As I said above, the 2.7 and 3.0 diesel engine tensioners are all the same. The one in the eBay listing you reference is the correct one. |
citroenroen1 wrote ... I googled the part# 5751 C5: tensioner for Citroen C6 and nothing came up. I found this listing: "1611424480 BELT TENSIONER PEBBLE FOR CITROEN C5 III C6 407 607 2.7-3.0 HDI." on EBAY. Is same serpentine belt tensioner used on all C6's? PSA group went through a process of changing part numbers across the group to ten digits from the old 4 digits letter digit system, so you can often find parts listed on either or both systems. I personally used to have access to the online parts search, but that was withdrawn years ago, I'm afraid. Confused? Well it's a French car ![]() |
