Brake Fluid Change |
joopajaa |
Member No: #3261
I had to quit the bleeding via diagbox since the on-screen advices were very badly written (I quess from fra - to eng to fin). The ABS pump sounded pretty bad depending how I pressed the pedal as asked on the screen. Does someone know the right method for bleeding with diagbox (abs system bleeding it is I think)? Do you have to pump or just press the pedal? There was something like "pump 30-90sec" - if I do that I will need 10 liters of DOT4 to fill the hydraulics as the oil runs quite fast from the open bleeding screw (as told to open on-screen) I guess I should never be suprized with complecity of the french engineer mind... |
Joopa, I pumped the pedal when doing the secondary circuit bleed as instructed. The ABS pump does sound loud but that is normal. I can't remember how much fluid was used but it wasn't 10 litres or 5 litres. As regards the technique I just followed the Diagbox instructions. I had the laptop beside me while bleeding and an assistant in the car doing the pedal work. Best regards, Phil C. |
