C6 technician |
Riffe |
Member No: #1615
Does anyone know of a good C6 technician in our around the Northampton area please | ||
Whats the scope? | ||
Riffe |
Member No: #1615
Hi Gmerry Trying to fix a ABS fault error code C1336 which indicates rh rear sensor which I changed, I still have the fault so could be cables, In Citroen's designers wisdom the cables/connectors are above the fuel tank, which means dropping the fuel tank. Could however be something to do with the CAN bus as other errors are P1351/P1536 so a experienced technician could sort this. Thanks for your reply |
Have you tried a diagnosis with Lexia or Diagbox rather than a generic code reader. This will more readily get to the root cause of the issue. Perhaps someone will offer to help with Lexia? If you have already changed the sensor, was there any change in the diagnostics? regards G |
Hi Riffe, have a look at the notorious brake pedal switch for error 1536, and i think error 1351 is for idir the relay or glow plugs themselves. Both errors are fairly common on the cars. Ive got 1351 myself at the moment. |
- Click Here - | ||
Riffe |
Member No: #1615
I am getting to grips with Lexia at present, the problem is at the moment is interpreting the fault codes in what order, namely P1351, P1536, U1213, C1335 & C1336. Visually I get the yellow ABS, and triangle, some of the above faults may be related not sure. |
It might sound like a daft thing to say, but....... have you cleared the faults off? I just wonder if they are historic faults | ||
Trainman wrote ... It might sound like a daft thing to say, but....... have you cleared the faults off? I just wonder if they are historic faults Thats true Steve, i did that myself (fail to delete the error codes and recheck if they came back on again). |
