Worried |
DZR |
Member No: #2168
As posted earlier, I´ve just bought a Diagbox software from Easydiagnostics, and I´m now slowly learning to "handle" it. At my first diagnos I did get a red line saying "Communication error" with the right headlamp hight adjuster. Today I discovered the little folders to the left of certain ECU:s, indicating errors. I found the following fault codes: U1116 U1118 U1205 and U2005. Not sure what I´m looking for, I decided to take a look at the fuses. Lifted the cover under the hood, and found a couple of cables that was cut and isolated. (see pictures) I am now very worried, as I can´t find where this cables are supposed to be connected. Could this have something to do with the fault codes I´m getting? |
Cables that are not required on your model. | ||
DZR |
Member No: #2168
Thank you e3steve! I was a bit worried over them, since it looked like the insulation was homemaid.. | ||
DZR wrote ... My 2.7 has several like that in the electronics' box under the bonnet!Thank you e3steve! I was a bit worried over them, since it looked like the insulation was homemaid.. |
DZR |
Member No: #2168
Thanks! Now I must find out what the error codes means, U1116 U1118 U1205 U2005 and a connection error to the right headlamp hight corrector. Everything seems to work on the car, incl the headlamp, which is moving when I start the car. However, the car feels firm in the front and as it has poor damping in the rear. | ||
Error Code Info: - Click Here - U1116 - No tech doc but: Absence of communication on the CAN with the suspension ECU U2005 - No tech doc but: RCD fault: Vehicle speed information fault (absent or not valid) |
DZR |
Member No: #2168
Thanks, Dave! So no communication, neither with suspension ECU or BSI ECU via CAN (U1116 U1118).. I have non of the problems associated with U1118, no lack of power, no starting problems or jerking/stalling. I have no clue on where to begin. About the steering wheel angle, I think I read somwhere that it could be a bug in Diagbox/Lexia? If not, do you know if it´s possible to calibrate that sensor somehow? |
My garage people do not worry about the steering wheel angle signal fault, they just reset it, saying that it is a buildt in error that is not serious | ||
