Increase the video limit Lexia or Mira scripts???????????????
Gobxoy
Wed Nov 07 2012, 10:33am
Member No: #786
Hi I think this has already been covered, and I have another thread about fitting a review camera?
Can this be increased via the Lexia, I have mine booked in for tommorrow for winter tyres and swtich off the TPMS and change to 17" wheels. So While I am at it is this a LEXIA or Mira Scripts only change?????
OBviously I am fully aware that the olny legal use would be rearview whilst on the move which is what I am after plus reversing.
Quick answer appriciated owing to being booked in.
m3mpower
Wed Dec 05 2012, 10:37pm
Member No: #662
Hi
It you are talking about disabling the 5mph video speed limit, this can only be done with Mirascript, not with Lexia
Gobxoy
Thu Dec 06 2012, 08:36am
Member No: #786
m3mpower, whats the easiest way to do that is there a tutorial?
BTW my car has an RT5 with 8.30 software. I haven't found much out about the differences to 8.20?
I suppose it would be a good idea to back up the system first?
Thu Dec 06 2012, 10:11am
No need to back up the system if you have a set of 8.3 discs (you can get it online anyway)
Mirascriprts is here: - Click Here -
Unzip it and in the Docs Directory there is a pdf with descriptions of all the scripts and what they are for
Very easy to use, copy to a CD or USB stick (if USB is already enabled) and insert it, choose the scrip to run
m3mpower
Wed Jan 23 2013, 11:06pm
Member No: #662
Gobxoy wrote ...
Hi
Sorry didn't get back to you on this....
Did you get it sorted in the end?
Gobxoy
Thu Jan 24 2013, 09:36am
Member No: #786
m3mpower wrote ...
Gobxoy wrote ...
Hi
m3mpower, No not sorted yet, the camera works save can't use above 5mph.
The software 8.30 doen't appear to be available, even fron my Citroën dealer.
I have a interface unit from navlink which doen't work, it cuts out the video , but doesn't put the video back in through their input, and they are talking with the makers?
Either way it would be good to raise the video imput as it wil only be used for the rear veiw camera.
Any help much appreciated
m3mpower
Thu Jan 24 2013, 10:01am
Member No: #662
Hi No problem, i can help you with that.
You need to connect a USB cable to your RT5.
Then use a formatted ( fat32 ) USB stick, connect it to your PC, download Mirascript - Click Here - and extract the files onto the USB stick.
Open the CMD folder in the USB and delete all command script except "RTxSET".
Switch on the RT5 and connect the USB stick.
You will see on the display the following:
View / modify general section? answer yes
video speed limit, set to 225? answer yes.
Answer no to all other questions.
Answer yes to reboot.
Job done !
smihaialex
Thu Jan 24 2013, 12:56pm
Is there a similar mod for the RT3 using a CD instead of an USB drive?!?
Thank you,
Sam
m3mpower
Thu Jan 24 2013, 01:26pm
Member No: #662
smihaialex wrote ...
Thank you,
Sam
Hi
No, on the RT3 it's more complicated...and the USB method only works on RT4 and RT5
smihaialex
Thu Jan 24 2013, 04:47pm
Got it! Thanks!
Slightly related question: where can I get a CD with the latest version of maps for the RT3?!?
Thank you,
Sam
Thu Jan 24 2013, 07:10pm
Direct from Navteq: - Click Here -
Or look on gpsunderground.
Gobxoy
Fri Jan 25 2013, 12:50pm
Member No: #786
m3mpower wrote ...
You will see on the display the following: No I get "Audio track not recognised" Message???????
Job done !
I think I am missing something here's a pic of the usb stick
Just the "CMD" folder with the "RTxSET" script file??????? see pic. I checked it's Fat 32.
Fri Jan 25 2013, 01:28pm
You have to connect it to the car before the options appear in the Navi Drive screen........
m3mpower
Fri Jan 25 2013, 03:55pm
Member No: #662
Gobxoy wrote ...
It's ok, ignore that message, it's basically telling you it's not recognising the MP3 files...
Leave it a few more seconds and you should see the options I mentioned previously
Gobxoy
Sat Jan 26 2013, 12:40pm
Member No: #786
I pluged in the USB before turning the ignition on........no change, but will try again.
m3mpower wrote ...
Gobxoy wrote ...
I left it connected for more than five mins.......
No joy either yet BTW my sofware is 8:30.
