Rear Numberplate panel removal??
yorkxx
Sat Sep 08 2012, 03:18pm
Member No: #1005
Hi,
Anyone know how to remove the Numberplate panel/rear fog light etc?
It say's in the manual to remove the Four (X4) screws and pull, That don't work?
I don't want to break anything just in case there is a sneaky screw somewhere I don't know about.
Cheers
Hawkie
Sat Sep 08 2012, 10:16pm
Member No: #45
I had my numberplate panel off last week. It is not as easy as it says in the manual. But there are only the 4 screws that you have to remove. Then you have to lift the lower part of the panel just right out from the boot lid. The problem is that it is hold in place with 2 wings and a self-locking device... you have to be determined and use some violence. In my opinion the self-locking clips are unnecessary and I can not understand why they are there. When that is done it is easy to just pull down the panel. I did obviously not replace the clips.
Good luck!
/Hawkie
2 User said Thank You to Hawkie for this Post :
 C6Dave (09 September 2012) , userpco (12 October 2012)
yorkxx
Sun Sep 09 2012, 12:30am
Member No: #1005
Hi Hawkie,
thanks for your suggestion, spot on!!!!.
Got it off with a bit of a struggle, as you said it makes no mention of the two clips in the hand book, that's not good, someone has tried to take this panel off before on my car and broken two of the four screw/clip holders, I've made new ones from hard plastic and Araldite, thankfully it worked out ok.
It's a real nasty bit of kit Citroen used, one can imagine that there has been a few broken panels, clips and paintwork scratched too.
For any others interested in doing this work, make sure you have a thick towel or bit of material along the bumper to protect it, three hands would be good on this job too.
Cheers
2 User said Thank You to yorkxx for this Post :
 userpco (12 October 2012) , TonyFu (28 January 2015)
dsharples
Sun Feb 03 2013, 07:06pm
Member No: #119
I removed my boot-lid number-plate panel today, as a) I wanted to change the number plate screws which had rusted, forced off their caps, and where un-removable from the front, and were nicely staining the plate and car, and b) all of the 4 screw-clips were broken along the bottom edge - so needed epoxy repair. The 4 clips have progressively broken through use of boot, so it must be the vibration effect that causes them to fracture. I noticed that a coupe of the light mounts were fractured as well, so these are clearly a weak spot where the boot used daily as mine is....
MikeH
Tue May 31 2016, 07:57pm
Member No: #1555
Hi. I have tried to remove the panel and even with a bit of violence, it remains firmly fixed at what seems to be the area around the boot unlock switch. Can you let me know where these unmentioned retaining clips are and in what direction to apply leverage. Many thanks.
nouveaucitroenist
Tue May 31 2016, 10:10pm
Member No: #2222
I think there are some clips that go horizontally through panel so you have to pull it straight back.
userpco
Thu Jun 02 2016, 12:27pm
Member No: #622
nouveaucitroenist wrote ...
That's right and you really have to use a lot of force, needless to say I didn't replace the clips. I repaired the broken lugs by supergluing lugs made from ally angle
1 User said Thank You to userpco for this Post :
 sverre59 (23 April 2018)
MikeH
Sun Sep 04 2016, 06:19pm
Member No: #1555
Thanks to all and yes, the panel came off with a straight pull, albeit with a little force applied. I've attached a few pics of the panel off to illustrate how it is fixed in case these prove useful to others.
5 User said Thank You to MikeH for this Post :
 321dave (05 September 2016) , ul9601 (15 September 2016) , tich731 (03 April 2017) , cruiserphil (04 April 2017) , sverre59 (23 April 2018)
tich731
Mon Apr 03 2017, 07:09pm
Member No: #3023
A surprising amount of force was required to free the locating pegs at the top of the panel when I finally succeeded in removing it this evening. Thanks mainly to the advice given, and especially the photos, in this thread.
This forum is an invaluable resource. Thanks to all.
smorphet
Mon Jul 29 2019, 01:11pm
Member No: #88
I struggled with this panel myself at the weekend. Many thanks for the tips and pictures here, which helped. What I didn't completely understand, until I had it off, was the relationship between the horizontal clips on the back, and the locating pins along the top edge. I sketched the following, which hopefully will help someone else:
To remove the panel, remove four bolts (B). To disengage the clips (C) requires a hard backwards pull (1) at the bottom edge of the panel. The panel rotates about the top edge pins (A) which remain engaged. Finally, drop the panel (2) to release pins (A).
You can't just pull the whole panel backwards, because it's retained along the top edge. That's what I hadn't understood.
The reason for taking it off at all was to repair the four mounting points along the bottom edge, all of which were broken. It was also an excuse to play with my new 3d printer. I made some little blocks, with captive nuts, that were epoxied into place.
It seems to have worked. The panel fits tight and flush with the boot lid in a way that it hasn't done for years! I just hope the glue holds.
Steve.
1 User said Thank You to smorphet for this Post :
 cruiserphil (29 July 2019)
Mon Jul 29 2019, 02:21pm
Thanks for that update Steve,
A very elegant solution. It looks like the original mounting points break away from the impact of boot closing over time.
From the piccy, I understand the block with the captive nut, what are the larger blocks? Are they spacers?
smorphet
Mon Jul 29 2019, 02:47pm
Member No: #88
Thanks Phil.
The two larger blocks are exactly the same concept as the smaller ones, but they fit in the two outer positions. There's a hex pocket for a nut at the bottom of the big hole.
You can see, in MikeH's pics above, that the return on the lower edge of the panel has a little kick up around the outer mounting points. The taller blocks simply fill that deeper space.
Steve.
Tue Jul 30 2019, 07:59am
Thanks for the reply Steve,
It's a while since I had that panel off so I had forgotten. I had to do a repair but nothing as good as yours. I'm actually not happy with the repair as an excessive gap still exists between the top of the panel and the boot lid. A friend of my son has a 3D printer so I'm going to commission a set if you don't mind?
smorphet
Tue Jul 30 2019, 10:22pm
Member No: #88
Phil,
You're very welcome to copy my bits. I've uploaded the STL files to Thingiverse, so you, or anyone else, can grab them from there:
I hope they work for you. Let me know how you get on.
Steve.
[edit - files now available]
3 User said Thank You to smorphet for this Post :
 MarkBevan (31 July 2019) , cruiserphil (31 July 2019) , eke (31 July 2019)
