Compact Disk Changer in boot not working |
bdeithrick |
Member No: #70
Hi all my Compact Disk Changer in the boot wont eject its cartridge to load some cds into it. im i doing something wrong or not doing something right. ? all i have done i press the eject button behind the slid door ? pls help because the new Iron Madian and Airbourne cds are coming out. |
verycleverman |
Member No: #65
bdeithrick wrote ... pls help because the new Iron Madian and Airbourne cds are coming out. Think of an infant being spoon fed. If he objects strongly to the food you are trying to feed him, he will clamp his mouth shut. Maybe you should rethink your choice of CDs. Pete. |
Never had a boot mounted one but the arm rest one on the C4 used to be a bit touchy at times, especially in cold weather It used to sort itself out when it warmed up though. |
bdeithrick |
Member No: #70
no luck here then , A mind of info. for a verycleverman i did not get a chance to into the car to good rock. maybe some French ballets might do | ||
Dave Mc |
Member No: #64
I haven't had a problem with the unit in the C6 but have in the past with XMs. I found that if I gently pushed in the cartidge while pressing the eject button it normally worked. If it is really stuck you will have to take the unit out and use the emergency eject hole. I have used a straightened paper clip to do this. Hope these tips help. Dave |
Dave Mc |
Member No: #64
Just remembered, cycling through the discs before ejecting the cartridge also works | ||
bdeithrick |
Member No: #70
wow must try these tips ,, thanks | ||
tonyrome |
Member No: #15
bdeithrick wrote ... pls help because the new Iron Madian cds are coming out. Mine is full of Mozart & Beethoven symphonies . Somehow, Iron Maiden in a C6 seems all wrong, almost as though you've got into the wrong car - "excuse me, Sir, your Focus RS is over there". |
I have everything from AC DC to ZZ Top on my iPod in the car interspersed with things like Paul Weller, Beautiful South, Bob Dylan, Dean Martin, Toy Dolls, Motorhead plus too many others to list, a very eclectic mix on random play which can give some interesting sessions | ||
verycleverman |
Member No: #65
tonyrome wrote ... [Mine is full of Mozart & Beethoven symphonies . Somehow, Iron Maiden in a C6 seems all wrong, almost as though you've got into the wrong car - "excuse me, Sir, your Focus RS is over there". Just the point I was trying to make - though I lean towards The Moody Blues and The Phantom Of The Opera. Pete. |
Off on a tangent. I loaded the young one's Glee Album onto the Juke Box. 17 tracks took a long 15 minutes to copy. On later playback, 6 tracks present (not 1-6 either). All the rest are gone or hiding! | ||
