New hydraulic pump with complete electronic unit. |
Anders |
Member No: #4235
Hi Everyone. Renovated pump from Poland. Would like to use the electronic on the new pump. Advice needed regarding programing. Have diagbox as diagnostic tool. Thanks in advance Anders |
No programming required. It should swap straight in without issue. |
Anders |
Member No: #4235
Thanks MGmike. Any known procedure to get it running, Can activate the pump via diagbox diagnostic tool. But the pump will not start when open door etc Many thanks in advance. Anders |
onthecut |
Member No: #2793
Hi Anders. Is it failing to run just when the door is opened, or not running at all ? Mine is erratic with regard to the door --- sometimes it does; sometimes it doesn't, but it (so far) seems to put itself right once the car is started. Mike. |
Anders |
Member No: #4235
It's no activation of the pump in normal conditions only by the diagbox. Could their be different electronics on the pumps C5/C6 ? Have no ide what the company in Poland have put on mine ??? Have some progress , By diagbox I manage to get some movement on the suspension, so the pump is working, Many thanks in advance Anders |
Anders |
Member No: #4235
Up and running, found the problem All the parameters in section below must be programmed as Present. Hade one that was Absent (ECU parameter 2) Hope this helps for some one else Thanks Anders |
