Odometer reading correction |
Robert |
Member No: #3321
I have an unusual issue. My C6 has just under 98k miles I have a spare digital dashboard as it's a known failure point. I plugged the spare into the car to test it, it worked fine but showed 233k miles; presumably the mileage of the donor car. Having replaced the original dashboard the reading is still 233k miles, not the correct 98k miles There must be a way of forcing the display to read the correct car mileage when the display is replaced, but I cannot see any references to what that method might be. Any insight would be very welcome. Many thanks Robert |
cit-rotti |
Member No: #3753
It is not possible with the DIAGBOX and I doubt that it is possible with "legal" methods. We had to change the speedometer unit on a C5 R and now have 320000KM instead of approx. 195000KM. Help will probably only be available from the so-called "speedometer resets". However, not only the speedometer must be corrected, but also the entries in the corresponding control units (BSI; injection ECU, etc.). Greetings Wolfgang |
