loud bang followed by Depollution system faulty |
StirlingC6 |
Member No: #5131
Picked the 2007 model year 2.7 HDI up today after an oil change, A/C recharge and replacement of one of the A/C system pipes. All seemed fine for the first 7 or 8 kms. While going up a hill there was a loud bang under the car, followed by a partial loss of power, and the message "Depollution system faulty". I was able to get the car home with sometimes full, sometimes partial power. Any ideas regarding this strange occurance? |
It will need to go back to the garage for a code read but lets hope it's something simple like the air intake pipe not fitted correctly and coming off the inlet manifold! | ||
onthecut |
Member No: #2793
As MGMike says, inlet manifold pipe is definitely worth a look. It's also a really easy one to check -- at the top end, anyway. The attachment part is the first piece of plastic you see if you look at the engine directly across from the expansion bottle. It has a big wire spring clip on the engine side and the air supply hose on the bottom, secured by a Jubilee clip, just by the chassis rail. On mine, it required a significantly firm, square push to get the spring clip to properly seat on the manifold spigot. If it's not -- it blows off. (You don't need to ask how I know. ) Mike. |
StirlingC6 |
Member No: #5131
Turned out it was the line to the intercooler. When they replaced the A/C pipe apparently they didn't tighten that one back up. |
Hello StirlingC6, Thanks for the update! Best regards, Phil C. |
