Reversing Lamp Bulb Replacement
mister_iainm
Mon Jan 30 2023, 05:28pm
Member No: #3253
As per the title - can "we" do this? I recall reading something about taking it to Citroen (to which I might say - not in this zipcode etc...).
I mean... it's a bulb, with a finite life. It's gonna go (and one of mine has).
Answers on a postcard, or the forum!
Tue Jan 31 2023, 01:51pm
Hello mister_iainm,
You can. Check out the posts on how to remove the boot registration panel. Also when you do remove check that the failed reverse lamp is not a bad connection. Mine was a bad connection.
Fri Feb 10 2023, 12:50pm
As Phil says, you can. If you're not confident, bring it over to Kirknewton and I'll help.
Best regards
Michael
