Under bonnet fuse box |
Davet49
![]() Member No: #3695
My under bonnet fuse box is different in layout to the one described in the handbook. Did Citroen change the layout without updating the manual? If they did, does anyone have a diagram of the later fuse box? |
Hello Davet49, Would you let me know your RPO no. and I'll dig up the schematic! Best regards, Phil C. |
Davet49
Thank you. But, pardon my ignorance, but what is the RPO number? | ||
Hello Davet49, It's the 5 digit number with the CJ on the end on the sticker on the front door pillar that shows tyre pressures: - Click Here - Best regards, Phil C. |
Davet49
Thanks Phil. 11405CJ | ||
Davet49
After a couple of exchanges with Phil, we have discovered that the underbonnet fuse box on my C6 is not the one expected given the RPO number. It would appear that mine is the same as that fitted to the 2.7Hdi C5 X7 (last version of the C5) with hydraulic suspension. Citroën must have made a change and not documented it or updated the schemes. My thanks to Phil C for all of his help and providing me with a pdf of the correct fuse box. |
Fraunie
![]() ![]() Member No: #3763
Very interesting as your RPO Number is saying that the car was built on the 29th of January 2008. My C6 is officially a late 2008 but was built April 2007. It looks like as if most of our cars were in the possession of dealers quite some time before they have been sold to a customer... | ||
