Suspension wiring colours |
WGP |
Member No: #5076
The hydraulic suspension pump does not run when I turn on the key or the fob when I walk up to the car, as it did before, which seems to be a common issue. As there is no power coming through the wiring to the pump, which wire carries to the pumps, because there was a ground wire. Where does the wire originate? The fuses are fine. I need to know the wire colours and their path from origin to destination. Anyone else have this same issue? TIA |
