Rear door can not be opened |
mash-by-mash |
Member No: #1309
History Right rear door cannot detect opened status. Open door with rear or internal handle - window goes down. But immediately after the door handle release window goes up (sensor switch always think the door is closed). Ok. Purchased used rear electric lock. Replace. Test. Close door Pull external - window goes down, door opened, window in normal down state. Close the door. window goes up - OK! Assemble the door. Close the door. And found - can't open the right rear door inside. Left rear door - ok (it's about children safety) Then i'm doing big mistake. switch off plastic switch on door side and close the door External handle - deactivated Internal handle - not working What to do? My diagnose - used electronic lock have problem with children safety. hoot fix if the door is closed? (yes i can partially disassemble the door inside - already have try to disconnect electric cable - not working internal not working external connect it again Now i'm asking for help. |
mash-by-mash |
Member No: #1309
central lock - lock/unlock change nothing children safety button - problem detected. Children safety cannot be activated, immediately deactivated. |
