Gearbox fluid change - best fluid ... and is there a filter?
StuartA
Thu Jan 06 2022, 07:42pm
Member No: #4909
Hi everyone,
Can't find any record of the car (2009 2.7HDi) having a gearbox fluid change, so the local garage is going to do it for me. The owner lets me buy the oils & fluids and he just charges for the labour.
I've had a look at old threads but can't find anything more recent than 2013, so please be kind with me ...
Is there a filter in the gearbox?
What is the recommended gearbox fluid, given technological advances, or do I just replace with original spec?
How much will I need to buy, please?
Many thanks,
Stuart
Thu Jan 06 2022, 08:36pm
I've used this - Click Here - They also do 20 ltr drums.
3 ltrs for a standard change but for a full change you'll need 3x that amount and a patient garage to drive the car for some miles and drain again. I've opted to drain and refill at 10k intervals.
No filter but some people are replacing the oil cooler as a precaution.
StuartA
Thu Jan 06 2022, 11:09pm
Member No: #4909
That's great - thanks for the swift reply, Michael!
Stuart
Thu Jan 06 2022, 11:10pm
There is much and good information on this site. We should change the oil, at least before 100 000 km. I changed 3l on 50', 3x3x3l (full drain) on 125' and 3l on 200'. On the 2.7 engine the code for the oil is "3309" (like recommended above) and for the 3.0 it is "3324" or "AW-1".
Fraunie
Fri Jan 07 2022, 08:50am
Member No: #3763
There is a filter inside the gearbox.
But one would need to take the gearbox apart to change it...
IMHO "Gearbox Flushing" is the better choice to get rid of any kind of dirt instead of doing several changes.
There are quite a few gearbox-specialists offering that service...
Fri Jan 07 2022, 12:36pm
Hello Stuart,
I use this - Click Here -
StuartA
Sun Jan 09 2022, 09:14pm
Member No: #4909
Thanks everyone - very helpful indeed!
Stuart
