Instrument cluster: electrician consult asked |
pwvoogt |
Member No: #3906
I also had the known problem with the switching power supply. After I fixed it, the instrument cluster was working again. But now the VFD has failed. The VFD has been replaced, but the problem is still there. It must therefore lie in the management. I have measured the voltages, but I cannot judge whether they are all good. See the image with the left table. Is there an electrician who has measured the voltages on the VFD pins and knows what values they should be? I am very very grateful! central_display_faillure-instrument_cluster_citroen_c6.pdf |
pwvoogt |
Member No: #3906
Problem solved. There is not enough voltage difference between 1-4 and 23-27 (the ends of the filaments), so the filaments are not receiving power. This causes the entire VFD display to fail. The cause was a break in the print track at the transformer. | ||
