Depolution System Faulty |
Radox
![]() ![]() Joined: Aug 27 2019 Member No: #4044
I got this message last week. The Citroen Workshop read the fault codes, and they are as follows: - P0104 - P0405 - P010F If I am correct, they are pertaining to problems with the EGR valve and the Air mass sensor. My questions are: 1. How many EGR valves does the C6 have - one or two? 2. How many Air mass sensor does the C6 have - one or two? 3. If I change all these parts, will I notice improvement in performance, fuel economy, motor noise etc? Thanks. |
Fraunie
![]() ![]() Member No: #3763
1. Two 2. Two 3. Probably not... I would recommend to switch off and close the EGR-Valves... Here for example: - Click Here - |
These errors all originate from a rear EGR failure. The two MAF errors are caused by the EGR not doing what it is expected to. Change or clean the EGR and clear the errors. I'd be very surprised if the MAF error return. As mentioned above you could get a remap and EGR delete to improve the performance. |
Fraunie
get a remap and EGR delete to improve the performance. Frankly the car is driving so much better without EGR valves and 36hp more feels just right... ![]() |
