Serpentine belt image/routing |
C6Marcy
![]() Member No: #4417
I have a slightly worn bearing/whining noise coming from my 2008 2.7 serpentine area, the noise increases and decreases with engine revs Are there any diagrams so I can visualize the area before I start taking the car apart to diagnose I'm assuming it's the alternator pulley but guessing can get expensive |
C6Marcy
Found this in the docs section The timing belt doc has a great pic of the serpentine arrangement |
FraserG
![]() ![]() Joined: Jan 05 2015 Member No: #2011
Don't ignore the noise. I did and wished I hadn't. The belt failed at speed half way around a fast curve and all of a sudden I had no power steering! It was at that point that I realised how light the steering normally is and how weak my arms are! Luckily no damage done although it wrecked my holiday weekend and the car went home on the back of a truck. |
C6Marcy
Sorry to hear that, do you know which part failed to make the belt come off? | ||
My belt failed twice: 1. the generator clutch 2. The tensioner. The last one was an error at the garage repairing no 1, failed to check torque for the fastener. | ||
FraserG
C6Marcy wrote ... Sorry to hear that, do you know which part failed to make the belt come off? The belt was squeaking for a while which I was putting off doing anything about until the next service in a few months. The belt broke. Just like fan belts used to when I was a kid. ![]() |
C6Marcy
C6Marcy wrote ... I have a slightly worn bearing/whining noise coming from my 2008 2.7 serpentine area, the noise increases and decreases with engine revs Are there any diagrams so I can visualize the area before I start taking the car apart to diagnose I'm assuming it's the alternator pulley but guessing can get expensive Ended up being the Poly belt deflection pulley/idler Managed to split the two halves of the pulley and replace the 6303 bearing, cheap fix and tested the OAP in the process Result |
