Serpentine belt image/routing
C6Marcy
Thu Jul 30 2020, 07:09am
Member No: #4417
I have a slightly worn bearing/whining noise coming from my 2008 2.7 serpentine area, the noise increases and decreases with engine revs
Are there any diagrams so I can visualize the area before I start taking the car apart to diagnose
I'm assuming it's the alternator pulley but guessing can get expensive
C6Marcy
Thu Jul 30 2020, 05:50pm
Member No: #4417
Found this in the docs section
The timing belt doc has a great pic of the serpentine arrangement
1 User said Thank You to C6Marcy for this Post :
 Trainman (31 July 2020)
FraserG
Thu Jul 30 2020, 11:04pm
Member No: #2011
Don't ignore the noise. I did and wished I hadn't. The belt failed at speed half way around a fast curve and all of a sudden I had no power steering! It was at that point that I realised how light the steering normally is and how weak my arms are!
Luckily no damage done although it wrecked my holiday weekend and the car went home on the back of a truck.
1 User said Thank You to FraserG for this Post :
 cruiserphil (Last Week)
C6Marcy
Thu Jul 30 2020, 11:52pm
Member No: #4417
Sorry to hear that, do you know which part failed to make the belt come off?
Sat Aug 01 2020, 01:24pm
My belt failed twice: 1. the generator clutch 2. The tensioner. The last one was an error at the garage repairing no 1, failed to check torque for the fastener.
FraserG
Mon Aug 03 2020, 09:17pm
Member No: #2011
C6Marcy wrote ...
The belt was squeaking for a while which I was putting off doing anything about until the next service in a few months. The belt broke. Just like fan belts used to when I was a kid.
C6Marcy
Wed Aug 05 2020, 11:49am
Member No: #4417
C6Marcy wrote ...
Ended up being the Poly belt deflection pulley/idler
Managed to split the two halves of the pulley and replace the 6303 bearing, cheap fix and tested the OAP in the process
Result
 cruiserphil (5 Days ago)
