colling Fan fault 0493
joaoproenca
Wed Apr 22 2020, 10:19am
Member No: #1510
Dear All
I have following symptoms
- error code 0493;
right engine cooling fan is not working
left engine colling fan works always at high speed
Did not start to dig into issue
- i will start to look into fuse;
- connect right fan directly to see if it run with direct energy supply;
I m also looking into electric diagram of colling system in case i need to dig more
Warm regards
Joao
Thu Apr 23 2020, 09:37am
If the solution is like the one in XM V6, one of the relays (2 of them) may be the problem.
 cruiserphil (27 April 2020)
