Changin RPM on N (2.7 HDI) |
joopajaa
![]() Member No: #3261
Have anyone else noticed that when trying to maintain certain RPM on neutral it will slow down the RPM. I mean I try to maintain 1000RPM or 1500RPM -> RPM will decrease (the pedal is not moving) for several hundred RPM. Faulty pedal sensor? Leaking air? MAP-sensor (is there one on 2.7?)? As told on other topic I have had srange readings from MAF's: they give different readings (changed them a cross). |
Yes there is a 'MAP' sensor, cleaning that may help, have a read through this: - Click Here - | ||
joopajaa
I cleaned the MAP sensor but no difference. Did not had time to see the sensor data this time. | ||
