Seat
rmonf24
Fri Nov 08 2019, 05:08pm
Member No: #3300
Good people, cleaning the car I found this loose connector under the driver and passenger seat, does anyone know what it belongs to? Thank you
Fri Nov 08 2019, 07:30pm
Been asked before but I can't remember the answer.....
Is your car a Lignage or Exclusive specification?
rmonf24
Fri Nov 08 2019, 09:41pm
Member No: #3300
Exclusive
Paulius
Sat Nov 09 2019, 11:07am
Member No: #1821
I remember when I found such a connector, it turned out that it was a disconnected seat pressure sensor so that it would not beep when passenger doesn't have the seatbelt fastened.
rmonf24
Sat Nov 09 2019, 10:18pm
Member No: #3300
Paulius wrote ...
Well, trying the seat, I do not notice that it is hot, if it sounds if I do not wear the seat belt, and if it vibrates when I change lanes, the seats have heated all the seats without problems, what surprises me is that they have disconnected both seats.
Paulius
Sun Nov 10 2019, 01:18pm
Member No: #1821
Oh that, I have such "disconnected" connectors as well! An exclusive with no lounge pack here.
rmonf24
Sun Nov 10 2019, 07:20pm
Member No: #3300
What I see is that the front seats don't heat me up, if I'm not mistaken they have separate fuses, don't they? that melt both at the same time seems odd to me, the loose connectors then what extra is it?
Mon Nov 11 2019, 01:07pm
i wonder if it could be for the memory module on LHD cars?
rmonf24
Thu Nov 14 2019, 07:24pm
Member No: #3300
the fuses of the heating of the front seats where are they?
Fri Nov 15 2019, 08:15am
rmonf24 wrote ...
Dashboard Fusebox G35 and G38 15 amp shown in the owners handbook.
rmonf24
Sun Nov 17 2019, 11:09am
Member No: #3300
hello, I only see the fuses in box c, those in box b I don't see them. Thank you
rmonf24
Sun Dec 01 2019, 02:10pm
Member No: #3300
In the end I found the fuses and checked that they were fine, so I don't know what else to look at
arconell3
Tue Dec 03 2019, 10:46pm
Member No: #922
There are 2 heating mats, worked into the foam underneath the leather upholstery. One in the seat cushion and one in the back, connected in series. The heater control box is attached to the seat frame under the seat.
The wires run from the box and disappear inside the seat, where they are connected to soldering pads on the heating foils. In most cases this is where the wires come loose.
You can try to take the seat cushion out (see under technical documents), and, using a sharp knife, carefully slice the foam following the wires until you reach the broken joint. Resolder the joint and carefully glue the sliced foam parts together again.
