Driver Seat Memory Problem
Mon Nov 04 2019, 09:13pm
All, one of the less important but none the less very annoying issues I have is being unable to store seat/mirror position info. Lexia reports a memory module power supply issue but before I can check it with a meter I have to find it!
I've been through the tech section without finding a solid steer and therefore I thought I'd ask if anyone knows where it is or has fixed a similar problem?
Your guidance is appreciated.
Tue Nov 05 2019, 10:18am
Unfortunately a Windows Update has killed my VMware player running the EPC and I can't upgrade that as my CPU is not supported so can't run wiring diagrams until I upgrade my PC.
However the heated front seat wiring guide mght help - Click Here - as it shows locations of items needed including the switches etc. also the ECU location guide - Click Here - might help in conjunction with it
Tue Nov 05 2019, 02:26pm
Found a 'workaround' to get the system up and running and found the specific Driving Position Memorisation wiring Diagram - Click Here - which will hopefully help Mike
4 User said Thank You to C6Dave for this Post :
 MGmike (05 November 2019) , Eric (05 November 2019) , cruiserphil (05 November 2019) , 321dave (06 November 2019)
Tue Nov 05 2019, 04:15pm
Dave, you’re an absolute star
I’ll have a read and see where it takes me
1 User said Thank You to MGmike for this Post :
furriegurrie
Tue Nov 05 2019, 04:34pm
Member No: #2448
Keep us posted please! I seem to have the same fault in my C6!
