I got a very well kept C6 |
Radox |
Member No: #4044
C6Dave wrote ... If the cruise still doesn't work swap out the brake pedal switch as that can cause cruise not to engage (as can a faulty rear ABS sensor) The Cruise control works seamlessly, BUT when I select the Speed limiter it shows SERVICE + warning on the screen that the system is malfunctioning. The folks at Citroen told me that I will need a new COM-unit (complete with wiper/lighting stalks) on the steering wheel, but it is too expensive. Do you have any idea what might be causing the Limiter not to function? |
The folks at Citroen told me that I will need a new COM-unit (complete with wiper/lighting stalks) on the steering wheel, but it is too expensive. Do you have any idea what might be causing the Limiter not to function? If cruise works but limiter doesn't then it could potentially be the comms unit. You could swap it for a 'used' one from a breakers rather than pay the silly money Citroen want. My current car had the unit replaced by the previous owner which was such a used part. |
