Front windows noise
Nikola
Sun Aug 04 2019, 08:33pm
Member No: #3613
Hello guys
I have problem whit front windows wind noise.
It’s on motorway speed on 130 km/h and above.
The noise comes from B pilar. Any solution for noise reduction ?
Sun Aug 04 2019, 09:14pm
Nikola wrote ...
Hello guys
It's most like the seal has gone flat in profile from being closed for many years! You could try apply a silicone spray to the seal a few times and let soak in. Or it's €250 for a new one. It's fairly common on all frameless glass car door I'm afraid.
mtee
Mon Aug 05 2019, 06:46am
Member No: #1924
I had similar noise from the A pillar area. The root cause was that the window's top position was a few millimeters too high up. I discovered the root cause by stopping the rising window just before it was fully up.
The local Citroën garage solved the problem by adjusting the window position according to the factory specification.
Mon Aug 05 2019, 07:13am
Have a read of the FAQ: - Click Here -
It may be a simple fix.
