Fehler P0243 C6 DT17 SID201 |
cit-rotti |
Member No: #3753
Hello, P0243 Turbo pressure regulation electrovalve 1 (rear) control fault: Mechanical problem. The error occurs after a short driving time - the C6 then has little power and turns a maximum of 3000 rpm at idle. There is no warning light - only loss of power. When the car is turned off and restarted, the turbo power will work again for a few miles - then everything repeats itself. Does anyone know this error / problem? Which possibilities of repair are there? Citroen only supplies a complete turbo with wastegate. And prohibits the wastegate from the turbocharger to separate, disassemble and release its attachment. Greeting Wolfgang |
joopajaa |
Member No: #3261
I would buy a second hand unit from C5/C6/407/607/Jaguar S-type/Landrover if the price for new one is too much. And I mean the whole turbo. |
check this thread - Click Here - . It's a known problem on early turbos (I've got one waiting to be fixed!). |
